Rear subframe bushings
  • dmoney(AB)
    • 1372
    Alright so I know my bushings are shot and I have new ones ready to go in but I thought I'd throw this question out there.
    Will old bushings cause the rear wheel to not be centered in the wheel arch?
    I have some 275/40r17s on the rear and they fill the wheel well nicely but aren't centered in the opening.
    Here's some pics to show clearance. That clearance is gone under hard accel.
    I have 750lb springs in the rear as well
    TIA
    mtech1/2jzgte/r154/275tire
    function>form
  • jalopi
    • 2370
    Maybe, but it's most likely because of a trifecta of bad TABs, subframe bushings and the diff bushing.
    • tinkerputzer
      • Jun 2008
      • 508
      I think it would look centered if the side skirts weren't there.
      • Liquidity
        • May 2014
        • 395
        Ride height seems a bit high to me. The farther the trailing arm is from level, the farther forward the wheel moves from center as the arm swings forward.
        • dmoney(AB)
          • 1372
          Hmmm
          I have since lowered it in the rear some more.
          You may be on to something with the side skirt.
          I was on the dyno and found under high speed that the tires contacted on the body.
          Strapped down in this pic
          function>form
