I'm looking to purchase the Ireland Engineering 310mm BBK front and rear but don't know what wheels to get that will fit over them preferably without a spacer and a staggered set. Please let me know as I would like to order the kit tomorrow
IE 310mm BBK Rims
From what I understand, the 310 kit is pretty wheel friendly and doesn't require much to clear the caliper. Might be worth giving the guys at IE a call and ask about whatever wheel you have in mind. They're very knowledgeable and helpful.
I'm considering buying this kit, currently running arc-8 wheels. I believe this combo works ok. -
Do you have the specs of the wheels you will be running?From what I understand, the 310 kit is pretty wheel friendly and doesn't require much to clear the caliper. Might be worth giving the guys at IE a call and ask about whatever wheel you have in mind. They're very knowledgeable and helpful.
I'm considering buying this kit, currently running arc-8 wheels. I believe this combo works ok.Comment
Thanks for the links but I have already read those threads, I'm looking for a better looking wheel with an open face. This may seem like a dumb question but is there any way a Kosei K4R 15x8 can fit the 310mm kit front and rear?Comment
