Heading into Day 3 of trying to get the subframe dropped so I can do what I originally had planned to do (R&R subframe bushings and RTABS… wanted to do them with as little effort as possible and boy has that backfired…)
I was hoping to at least finished before I go to bed, but it's 3am PST now and I'm beat (worked on it 18 hours today, including several commutes to HF, Ace, etc).
My last hang-up get things dropped is the four bolts on the differential's input flange: I got the nuts off easily enough but are the "special bolts" supposed to come out, too? Because they ain't movin'…
I have not unbolted the CSB carrier yet which I'm guessing would block the universal joint from clearing the subframe tunnel, so I'm going to try that in the morning. If I just unbolt the CSB carrier – but not unbolt the driveshaft from the CSB – I should be able to get the universal joint out of the subframe tunnel by bending the driveshaft at the CSB, right?
I'm a week back into E30s after a 15-year hiatus and this job has had everything go wrong that could go wrong short of the car catching fire. Hoping tomorrow is brighter.
Thanks in advance!
Thanks in advance!
