Hi im wondering if anyone has used the raised subframe bushes from either rev shift or AKG. Have these bushes helped with camber and by how many degrees. Any feedback is appreciated. Im tossing up if i go with the raised bushes of go with the weld in kit. Thanks
Raised rear subframe bushes
I have the Revshift one, Took out more camber compared to how the car sat before. I would still like to weld in kits in the trail arms to get the toe and more camber out of the rear wheels. Worked how great since I was already replacing all the bushings so I just decided to do it. If your going for the stance look you may not want to do it because your gonna have a harder time rubbing like I did when I was on springs. -
I have 12mm riser bushings, last alignment spec'd at -2 degrees, but ride height is fairly high. Think it makes a bigger difference the lower you are?Comment
