Hey r3v,
I've been stuck past few days with some pesky bolts that won't come off of the caliper... My plan B was to remove the front strut from the control arm + trailing arm and try to complete the job with the caliper still attached.
I then realized there is no way to do that... Not enough room to work for me.
I've sprayed PB over and over -- over the course of 24 hours... It is also for me to gain leverage because it is separated from the ball joint. I've tried an impact wrench, which also didn't work.
What I haven't tried:
1. Breaker bar
2. Heat (torch)
Should I...
1. Remove the brake line to the caliper, and complete the job with the caliper still on the rotor?
- what is involved in this option? are there any special tools needed?
2. Reconnect to ball joint to get more leverage, + try breaker bar?
This is getting frustrating and I want to get the car on the road...
Ideas?
1. Breaker bar
2. Heat (torch)
Should I...
Ideas?
i have no idea what i am doing with my life
