so after giving up on my other stuck tie rod for a second I started taking off my driver side strut but when I was taking off the nut on the tie rod I noticed the STUD WAS TURNING TOO what do I do??
bigger tie rod problem!
Tags: None
You can cut it off or put a jack under it and add pressure to it until it stops turning.Current
99 328i (Sold)
91 318is M50B25TU
89 325ix (Parted out)
87 325is (Parted out)
95 525i (Parted Motor for 91 318is) -
could you further explain the method that doesn't include cutting the stud? it actually looks like there is a spot for a Allen bolt on the top? if that's what that is does anyone have any idea what size that is?Originally posted by VokuhilaI laughed, and then I seriousedComment
problem solved thanks for the adviseOriginally posted by VokuhilaI laughed, and then I seriousedComment
