Hey guys I just threw my rims on. Big rims and big tires but nothin that has not easily been run before. 17x9, 245/40. 22 offset and 12mm spacer. fender cut out.
My front tires hit the wheel well.
I am running offset control arm bushings.
I read through the stickies and it seems they effect caster (make it more positive) but no one talks about exactly how much. Im guessing I am missing almost 3/4" to an 1" of clearance. Could such a small offset in the control arm bushing translate to that touch more room from change of caster?
Is there any other way to move the wheel back to make more room?
The fenders are cut out in the pic so its a little hard to tell but if you look at the front I am about 1/2" from fender. It somehow just clears that but then hits the wheel well inside.
