Hi all,
I recently sense that there is a noticeable wheel pull (to the left). I checked the control arms + bushings and they look fine (of course I just changed them less than 2000 miles ago). The wheels are balanced so I moved my focus to the brake. The master cylinder was leaking and was changed 500 miles ago. So I checked my caliper and sure enough they were stuck at front, so I rebuild them with help of a mechanic (to ensure I am doing the right thing). I install a set of new brake line and did a bleed job at the same time. I did not bother to replace my brake pressure valve because from the manual I was told that this valve is for front/end brake pressure distribution.
That did not help and pulling is still happening, and I gave up, until my search on forum got me into looking at my ABS unit. I replace that with another one and finally the pull is 95% gone (I can't say completely gone because I can still sense a little, just a tiny little bit of pull).
By now I throw my towel and declare it done. I know it's going to take a much longer time for me to sort out why I still have that 5% pull left. However, if you guys have any other ideas, please feel free to share with me. Thanks!
Matthew
Matthew
