Mini BBK is done!
  • 2002maniac
    • 4260
    Mini BBK is done!
    Ok, I finished my setup last night but had a slight banjo leak this morning. I took my mom's Subaru to work and I fixed it as soon as I got home. Bled it all properly and took it out. My first impressions were "this sucks, what a waste of money" The pedal was squishy and the brakes stopped worse than stock with Pagid's. Off I went to bed in the pads. I went to a new subdivision near my house where they just finished grading the lots. No one lives there or anywhere close yet. Just a nice straight freshly paved road.
    I did 5 60-0 stops and then 5 80-0 stops. After this the pads were slightly smoky and the rotor and turned a blueish hue. (reminded me of chips off a lathe)
    I drove around a bit and let them cool down.
    HOLY HELL Pedal feel is awesome and they pull you down from high speeds like mad. I know that this is partly thanks to the aggressive pad compound but I know I wont be having fade problems like before. I'm off to Miller Motorsports track tomorrow
    Here are some pics for views (Pardon the dirty/ricey wheels. They are only temporary :( )
    Brake fade
    Tire smoke
    Here's where I'm at with my wilwood setup
    calipers $170 on ebay new
    Hawk HPS pads $50
    vw corrado Brembo rotors $35 ea
    Stainless lines with 1/8NPT Banjo fitting $30
    Custom brackets $25 in materials
    The calipers are Wilwood FBD 1.38" pistons for 1" rotor
    Unfortunately I'm not willing to make more brackets because I am lazy but I'll draw up a blueprint in MS paint when I get the chance.
    Any questions? $350 for a badass setup that fits under 15's!!!
  • King Luis
    • Sep 2004
    • 737
    that is sweet, i would definitly be interested in doing a setup like that for sure.
    a how to would be awesome.
    describe the custom bracket a little more please. and more pics.
    was everything simple bolt on?
    • mrsleeve
      • Mar 2005
      • 16385
      I was just thinking about doing something similar. Would love to get some part numbers, and the print for you bracket.
      Originally posted by Fusion
      William Pitt-
      • 2002maniac
        • 4260
        Besides the custom bracket yes. Anyone with acess to a manual mill could whip up a set of brackets pretty easily.
        I also had to trim the backing plates a bit to clear the rotor.
        • Jand3rson
          • 37587
          The brakes look awesome behind the wheels, awesome work. I bet they stop like a motherfucker.
          • e304me
            • Feb 2006
            • 1374
            make
            brackets
            • Ferret
              • May 2005
              • 101
              What is the corrado disks diameter?
              What material did you make the brackets from?
              • rs4pro3
                • 5808
                280mm
                85 325e 2.7 ITB'd stroker
                • Ferret
                  • May 2005
                  • 101
                  Ithought the 280mm ones are 5 hole and the 4 hole ones are 256mm.
                  • Bitburger
                    • Jan 2004
                    • 147
                    VW made 280mm rotors in both 4 and 5 lug.
                    • browntown
                      • Jun 2004
                      • 3524
                      ok im interested, but I may be confusing projects. Dont you have to modify the rotor or the hub to make this work due to the center-bore?
                      • 2002maniac
                        • 4260
                        Yes, this is true. I opened up the centerbore of the rotors. Very easy mod if you have the right tools.
                        • King Luis
                          • Sep 2004
                          • 737
                          i think you need to post a how to or a DIY thread.
                          • bimmers4life
                            • 420
                            brakes look sick! i have been thinking about making a kit like that for a while.. I think i speak for everyone here when i say that i would love to see a write up or at the least those blue prints.. good job man!!!
                            • bimmers4life
                              • 420
                              any news on the diagrams for the brake kit?
