Control arms...
  • Spencer
    • 767
    Control arms...
    I'm looking for a good write up's on replacing control arms?
    -Spencer
  • RobertK
    Kicked cancer's ASS.
    • Jun 2005
    • 5864
    Not sure if there is one.. it's a pretty straight forward procedure. If you haven't already I would suggest investing in a Bentley repair manual.
    You basically remove your strut assemblies, loosen & seperatate the ball joint from the subframe and pop the new ones in. Shouldn't take more than 30 mins for each side with the proper tools. I suggest that you might also replace your control arm bushings while you're at it. The only tools you really need to accomplish this is a vice, a 19mm socket, and hack saw.
    I also suggest that you purchase a 22mm racheting box wrench, you would benefit greatly from this purchase I can assure you.
