Piston won't push all the way back!!
  • Th3importedguy
    • Mar 2014
    • 190
    My rear caliper piston won't push all the way back I think. When i put the new pads on they won't go back on the new rotor. The space between the pads is too small.
    E30 is life :finger:
  • arch4ngel
    • Dec 2008
    • 791
    c clamp
    Project
    Feedback
    • Th3importedguy
      • Mar 2014
      • 190
      Originally posted by arch4ngel
      c clamp
      I pushed it back will a lot of force
      • Th3importedguy
        • Mar 2014
        • 190
        With a c clamp
        • long tall eta
          • Jul 2010
          • 1536
          use a clamp, ur hand won't do it most times.
          • Th3importedguy
            • Mar 2014
            • 190
            I did use a clamp to the point where the end of the clamp got a little bent
            • LJ851
              • 7919
              You're on a roll, aren't you ?
              Lorin
              The M30 is God's engine.
              • Th3importedguy
                • Mar 2014
                • 190
                Just a bit lol
                • AndrewBird
                  The Mad Scientist
                  • 11898
                  Calipers might be rusty inside and are causing the piston to get stuck. How does the fluid look?
                  • Th3importedguy
                    • Mar 2014
                    • 190
                    Fluid looks new
                    • AndrewBird
                      The Mad Scientist
                      • 11898
                      In the reservoir, or coming out of the bleeder on the caliper?
                      • Th3importedguy
                        • Mar 2014
                        • 190
                        Both
                        • matthugie
                          • Mar 2004
                          • 1810
                          They're probably worth rebuilding. The rebuild kits are pretty cheap and it doesn't take long. There's a DIY on it around here somewhere that I used when rebuilding mine.
                          88 325is - S52 powered
                          Originally posted by King Arthur
                          We'll not risk another frontal assault, that rabbit's dynamite!
                          • Das Delfin
                            • Sep 2014
                            • 2293
                            Also... take the cap off the fluid reservoir
