Hey guys,
So one of the previous owners of my car did a 5 lug swap (E36 m3 front Z3 1.9l rear), and in the process decided that they no longer wanted ABS. What I've noticed living in the PNW that it's pretty easy to lock up in the wet, even with 225/45R17 Michelin Pilot Sport AS3s. I've come into a couple of situations where panic stops were required in the wet, and I'd rather not chance it.
I'm about to purchase a new set of rotors and pads and if I upgrade to something like the Hawk HP+ or HPS 5.0 I don't want the increased risk of locking up, especially with my E36 M3 front brakes.
I still have my ABS pump and all of the hydraulic lines are still in place, but the ABS sensor wires are snipped at the back of the sensors, and there are no wires coming through the holes into the engine bay. There are no ABS warning lights on the dash.
So I guess my questions are:
- Is there an ABS module under the dash somewhere?
- Where do the wires from the ABS sensors route to?
- Where do the rear e30 ABS sensor wires route?
- Where is the ABS pump electrically connected?
- Is there a specific relay/fuse for the ABS to function?
Thanks
Thanks
