So I just finished up my 24v swap. I went to go for a little test spin and noticed my brakes didn't do squat. The pedal is super firm and will not budge except for maybe an inch, if that. It's like stopping with no brakes at all. What little distance I can pump, makes no difference.
So far diagnosing I made sure the direction of the check valve was correct and even removed it. Next up would be to check the condition of the oring on the master, but I don't recall it looking bad during install.
The setup in question is a E32 (aka IX) booster with an E36 M3 25mm master cylinder.
How likely is it that my booster is bad? If so, what interchanges that will fit that same master cylinder?
