IE rear subframe bushing install question
  • DoneRightBimmer
    • May 2012
    • 158
    Quick question about Ireland Engineering rear poly sub-frame bushings going to install today. I need to know if when installing the bushings do you reuse the large washer that goes in between the body and original bushings or are they designed to work without the washer?
    Thanks for help
  • BMWManiac
    • Dec 2010
    • 1091
    I don't think this is IE specific, but use the washer.....
    1997 Artic Silver M3
    CES GT4094r 651hp/615tq @ 24 psi
    • Nisse Järnet
      • Aug 2013
      • 1221
      I dont use it when installing hard delrin bushes but you should probably check with ie to be sure.
      E30 325ix M50 turbo 7 spd DCT 4wd 840awhp @ 31 psi.
      E30 M50 6 spd 764whp @ 24psi.
      E30 M20 6 spd 675whp.
      • tspangle88
        • Jul 2012
        • 134
        I used it.
        Tom - 85 325e for sale
        • dirty30
          • 3098
          always reuse the washer, does not matter if its factory, poly, delrin etc.
