Here's a stupid question. If I installed a Garagistic adjustable sub-frame should, and or do I still need to install the 12mm spaced sub-frame bushings along with the diff spacers? Or can I eliminate negative camber with just the new sub-frame?
Any or all thoughts will be appreciated. Thank you.
