Full suspension refresh where to buy??
  • Rdannyr
    • Nov 2013
    • 135
    Hi idk if this is the right place to post this but I just want to do a suspension refresh and was looking at poly bushings. I just wanted to see if anybody know a good place to buy and what sort of stuff I need. Should I go with polyurethane or other material?
    I was thinking of getting this http://www.condorspeedshop.com/colle...erential-mount
    Can I getter better prices elsewhere? What else do I need?
    Thanks so much to anybody that helps it will go a long way.
  • Rdannyr
    • Nov 2013
    • 135
    Also this is going to be a daily drive I don't mind a little stiffness or vibration as long as its not excessive. Its not a track car.
      • 37832
      I like to use Ireland Engineering for the rear subframe, trailing arm, and diff bushings. They are in Duarte as well. For the front control arm bushings I recommend going with OEM BMW E30 M3 offset bushings.
      Classic BMW Specialists
      Grover Beach, CA
      www.BimmerHeads.com
