Ate vs Girling Brakes
    I have an 87 325is with the Ate calipers, booster, etc and drove somebody's late body 325i recently. I noticed right away that the brakes felt way more like a modern car brake compared to mine. The pedal was much lighter and it took less effort overall to use the brakes. I also noticed that this other car had Girling parts rather than the Ate.
    My question is, do the early cars generally have a very different braking feel than the later ones? Do I just need to freshen up my system or am I likely dealing with something not working as it should? I did a 24v a couple of years ago and shifted my booster over to fit the engine. It's possible that it was damaged while running a little too much angle on the rod but I don't have any evidence of a vacuum leak. What do you guys think?
    Steven
    Pads make a huge difference. What compound do you have and what does he have?
    Keep it slideways!!
      Good point Axxe. I don't actually know the answer to either. I do think the difference was greater than expected if each of us were running street pads however.
        If you're on some autozone crap it will be night and day, even autozone to OEM pads.
        paint sucks
