What have you guys found when swapping to different calipers? When given the choice, should I try to come close to the stock piston area? Or should I increase a bit and then install the 25mm MC?
For example if the 25mm MC is 18% larger then the stock e30 one, then I assume I should increase the piston area by 18%. Although, to make the pedal a bit more stiffer, how much larger can I go? It looks like I will be running a 12.2" rotor, or 310mm.
