Wheel offset difference front to rear
  • dadsbmw
    • Oct 2014
    • 475
    What is the difference in offset between the front and rear on a late model e30? My eyeballing looks to me like its close to 15mm or 20mm. Anyone know what kind of spacer I should add to the rear to make it even with the fronts?
    2003 Z4 3.0 6-speed- Silver, 19's, daily driver
    1990 Silver 325i- Lowered on H&R OE Sports, e90 drop hats, KYB shocks, color matched rocker panels, 16" Emortal RS wheels on 205/50/16 tires... Currently getting a full refresh including an S52 swap!
    1997 Black Ford Probe GT- Stripped to 2220lbs, MS3X, Forged motor in midst of assembly... Dyno results and 1/4 mile times pending
  • straight6pwr
    • Sep 2004
    • 3450
    there technically is no offset difference, but I think you mean the rear tires looks more tucked inside the fenders than the front. anyways, it depends on the wheels/tires you are running and if you will have room. 20mm in the back with stock wheels/tires worked fine for me, but with 225 tires, I doubt if an 8mm would have fit.
    • E30SPDFRK
      • 5716
      Visually, the rears sit 15mm in more from the fenders than the fronts do.
      Byron
      Leichtbau
