No Brakes Help!!!!!
  • sticksdaman
    • Apr 2005
    • 2987
    No Brakes Help!!!!!
    After recently gettingy car back on the road i noticed that my brakes no longer work. upon applying the brakes there is no resistance the pedal shoots right down to the floor and once there it barely grabs not nearly enough to slow me down. i found that pumping the brakes twice got rid of this feeling. After driving for roughly 10 minutes (i was on the highway with no exits in sight plus i was taking my gf to work) it gradually worsened and it was to the point where i was pumping 5-6 times before any pedal feel was returned. So after exiting the highway i pull into the parking lot at her job and we sit in the car for maybe 2 minutes then get out. When i got out i checked under the car and there is this considerably large puddle of fluid under the passenger side of the engine bay( pretty sure it wasnt there when i pulled in) i also noticed that the front and rear wheels on the left side were covered in a thick layer of brakedust which is odd because this is the first time ive driven the car since cleaning them some 4 days ago. So i go to check the right side and they are clean as ever. Car is sitting in the drive way now. Whats causing this? How can i fix it?
    Thanks in advance
    Andre
    Originally posted by ebelements
    Also, for those who don't know, negative camber is the greatest thing since sliced bread(panera). Even tire wear is for city busses and the elderly.
  • sticksdaman
    • Apr 2005
    • 2987
    bump
    • netcsk
      • Apr 2004
      • 1609
      sounds like you blew out a line. Just need to trace down where the leak was coming from and then fix it. Might be time to do all of the rubber lines in the car even if just one blew.
      • sticksdaman
        • Apr 2005
        • 2987
        i have braided lines on the car now they couldnt have broken right? ive had them on the car for about 9.5 months but have only driven on them some <500 miles
        • KangamangusDriver
          • Aug 2005
          • 1870
          Braided lines can still break/leak.
          Check your clutch slave cylinder mounted in/on your transmission.
          Check master brake cylinder, and slave cylinder.
          Look for the leak, hunt it down and fix it.
          • SchnellerVert
            • Sep 2005
            • 3948
            Master cylinder. Seals in it are probably shot, clutch still works corect and fluid is in revoir? If you blew a line there would be less fluid in the resvoir.
            • sticksdaman
              • Apr 2005
              • 2987
              there was fluid in the resevior it seemed full but i'll try to hunt down the leak... also if one line breaks will that affect both wheels on that side?
              clutched seemed to work fine... engage wasnt as smooth as i remembered it to be tho
              • etxxz
                • Feb 2006
                • 2085
                have you lost fluid in the MC resevoir? if not then you probably have air in the sys or something that is easily fixed by bleeding the brakes. Try it out!
                No more e30s for me.
                88 black BMW OBDII 332is dedicated track [sold]
                88 BMW OBDII bronzit 332is [RIP 03/08]
                91 BMW 325i [sold]
                86 Corolla 'Ae86' HB 20v trd [sold]
                http://youtube.com/watch?v=pTj7Hn9v5Rs
                • sticksdaman
                  • Apr 2005
                  • 2987
                  ok ill bleed the system them take it from there
                  • sticksdaman
                    • Apr 2005
                    • 2987
                    bled the system... no help... im thinking its master cylinder..... whenever i clutch in the brake pedal loses pressure
                    also i have an 88 325is...now is that abs or no?
                    • Mike325
                      • Mar 2006
                      • 3685
                      I think that that has ABS. Just look behind your driver's side headlight and look for a box that has brake lines comming out of it. It is right on top and pretty much in your face. That is the ABS modual. If there was still full fluid in your resevoir for your MC, then the MC is gone most likely. Maybe the brake dust was your brakes dragging very slightly on that side? But anyways, if your resevoir was still full, I would get a new MC and try it out. If you busted a line, you would have no fluid.
                      Originally posted by Kershaw
                      • sticksdaman
                        • Apr 2005
                        • 2987
                        directly behind the headlight? how big is this box that i am looking for
                        • Garageaholic
                          Freestyle Fabricator
                          • Dec 2005
                          • 5204
                          It's a big box with 4 brakelines going into and out of it. I doubt that your lines are leaking from the ABS box...
                          Recent Rebranding!!
                          E30 SM62/S62
                          E30 M60 V8
                          E30 M30 Big 6!
                          Instagram.com/garageaholic
                          Youtube.com/garageaholic
                          • sticksdaman
                            • Apr 2005
                            • 2987
                            ok im nearly certain that my car is non abs
                            brake master cylinder... is it a must that i buy a new 135 dollar master cylinder or is there another alternative?
                            • PeaveyBassist
                              • Sep 2004
                              • 3511
                              '88 325is has ABS. The box says ABS on it if I'm not mistaken. I think its your Master Cylinder. Double check every connection of the brake lines though.
                              Will
                              RIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
                              Welcome e30 (brilliantrot '90 325is) 12/23/06
                              DaveCN = Old Man
                              My signature picture was taken by ME! Not by anyone else!
                              If people keep quoting me in their sig, I'm going to burn this motherfucker down.
