Hi there REV,
Wanted to get some thoughts on an issue I've had for some time now. Slow speed cornering popping and shifting of my rear. '88 325i vert. Sometimes the popping doesn't happen, sometimes it is a couple of little pops and 'shifting' (shifting of the rear of the car is unnerving, btw), sometimes its one major pop and shift.
I replaced the rear shocks (and mounts) when I got the car. Put a new circlip and seal inside the final drive passenger side (kind of where it seems like the popping is coming from) - I had noticed that that side's drive shaft was pulling from the diff and since the circlip, I have looked and looked, but I don't think that same problem is happening anymore. Just this past weekend, I did the guibo and CSB - CSB was complete trash.
The only other things I have in my possession already are the subframe bushings. Getting things together to get those on, but thought I would open up to anyone else with an opinion on what the problem could be. I've looked around and don't see any other rubber bits that are completely trashed.
Thanks for your thoughts.
