What is involved with installing e36 m3 brakes onto an e30 m3? I have access to some e36 m3 brake calipers with brackets, but I'm not sure what else I will need. Thanks.
For the front you will need the E36 M3 ft struts and the M3 spnidle/knuckle .
Or use regular E36 non-M struts with modified spindles/knuckles .
Or the other option is to use the SBI rotor spacer kit that allows you to run them on the E30 M3 struts/spindles .
For the rear calipers you will have to run the Mcoupe or Mroadster ttrailing arms like Smoodiver mentioned .
But the rear E36 M3 rotors will NOT fit on the MZ trailing arms .
E36 M3 Rotors and M-coupe and roadster rotors are IDENTICAL. Of course they fit.
Doh !
Must have been drunk posting again .
Just got carried away with trying to point out that the rear CALIPERS won't work .
Yes the rotors are indeed the same exact part with identical part #'s .
As far as running the E36 rear brakes on E30 triling arms ...I don't think so .
All of my E30 M3 buddies are running the MZ trailing arms to get them to work .
My set-up consists of E36 ft struts w/E36 BBK and M-Coupe trailing arms complete with brakes and halfshafts on the rear .
[quote]
That doesnt make sense, when you think about the fact that Z3 hubs and brakes can be mounted to the E30 trailing arms.. but i do know that the M-Z3 uses a much larger wheel bearing out back than E30's and 6 cyl Z3's so maybe the hub flange is different as well and for some reason makes it impossible to mount the M brakes to non M trailing arms.. maybe some z3 enthusiats can clarify that... i dunno if ive ever seen an M brake swap done on a non-m Z3
