One wheel farther out than the other.
  • Viking445
    • Apr 2013
    • 99
    Ok so recently my passenger rear has been rubbing like hell on the slightest dips or even just a having a passenger in the car. Its rubbed the lettering off the sidewall its hitting so often. Like the title says the passenger wheel is noticeably farther out than the drivers side. The rear subframe and control arm bushings were all replaced a year ago. Any ideas what this could be? Thanks!!
    89 320i Touring/M52 Swap w 4.10 Gears/K&N intake/Catback Exhaust/KW coils/Wilwood brakes/Azev A 16x7.5F 16x9R 215/40/16 F&R
  • lemansguy
    • Nov 2013
    • 205
    if all your bushings were replaced recently, then it sounds like you bent a trailing arm. i had the same problem but it was because my old rubber bushings had collapsed, causing one side to be uneven. new bushings fixed it. i would double check and make sure all your bushings are intact and torqued correctly, maybe one got damaged?
    '87 BMW 325i - ground control c/o, condor bushings, 16x8/16x9 wheels - SOLD
    '09 MazdaSpeed 3 - FOR SALE
    • Viking445
      • Apr 2013
      • 99
      Hmmm ok. The car is going up on the lift to look at other things but i'll double check the bushings. a damaged arm will be very easy to spot yes?
      • AndrewBird
        The Mad Scientist
        • 11898
        Depends on how badly it is damaged. If it's just a little, it won't be noticeable except when placed against another arm.
