Just wondering if there is a best way to go about getting these off? There kind of a pain to get to. Even harder to get some leverage on them. Or is the only option to get a wrench on there, and go at it? thanks
easy way to get control arm bolts off that go through subframe?
Do you mean the nuts? The left side is easy. The right side is a little harder to reach. I found taking off the heat shield around the CAB gave me enough room to get a regular 22mm (not positive about the size?) wrench on there and take it off. Both can be reached from below. Some people recommended getting a 22mm stubby wrench to take off the right side nut, but I found it wasn't needed. The 22mm wrench I used was a long (12-14") one, plenty of leverage. Maybe put another wrench on the open end side if you need some more torque to loosen the nut.
A pickle fork will take out the ball joint from the subframe.
Crow's foot, extensions, and a universal joint and go from the top.
WillRIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
Welcome e30 (brilliantrot '90 325is) 12/23/06
DaveCN = Old Man
My signature picture was taken by ME! Not by anyone else!
Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.
