rear subframe removal
  • NC325iC
    • Mar 2004
    • 6565
    ok what do i do about the ebrake line?
    and any other tips on taking it out would be appreciated
  • Alecs MacDonald
    • 729
    Get a couple of ziplock bags ready because as soon as you touch the ebrake assembly its gonna fall apart on you. Start by removing the top and bottom springs and then the hex key bolts. After that, the ebrake shoes should be free. The bottom cable assembly is held together by a single pin that just needs to be popped out. I find it easier to lay the parts out on a piece of paper, keeping them in the same orientation as I remove them. Also, no matter how hard you try, it is impossible to remove the passenger side trailing arm bolt without disconecting the fuel filler hose. As long as you have half a tank or less, you should get away without spilling much gas, if any. Another thing, the bolts on top of the subframe that hold the diff are known for being a trouble spot. I suggest you go ahead and hit them with some pb blaster or something of the sort. That is all I can think of right now.
    '88 325ic
    • NC325iC
      • Mar 2004
      • 6565
      so to get the cables loose i have to dissasemble the whole thing?
      • Alecs MacDonald
        • 729
        Unfortunatly, yes. Only after you remove everything can you pull the cable from the back of the trailing arm.
        '88 325ic
        • NC325iC
          • Mar 2004
          • 6565
          damn... well i guess i better get crackin on it. are there reassembly instructions in bentley?
          i guess its not a bad thing my ebrake has been sticking a little bit.
          edit: and is the filler hose attatched to the subframe?
          • Alecs MacDonald
            • 729
            No, the filler hose runs directly beside the box mount on the subframe. When you remove the trailing arm bolt it hits it.
            '88 325ic
            • NC325iC
              • Mar 2004
              • 6565
              is it really necessary to remove the TAs to get the subframe out?
              • Alecs MacDonald
                • 729
                You can drop the subframe with the arms attached. I have never done it this way, but I think it is much easier to remove them with the subframe still in the car. This whole job is really not that hard, just a lot of wrenching. Are you just replacing the subframe bushings?
                '88 325ic
                • Sean
                  • 5793
                  I removed everything together and put it all back on together. And honestly - it was a lot easier. You work hard to get the arms off and the diff off. Dropping it together worked great! Just use a jack to lower it down, and have a person on each side ot balance it.
                  For the ebrake lines, rather than mess with them in the hub, I said, fuck that. I removed them entirely from the ebrake handle, and pulled them out a little wase (since I left my arms beneath the car) This was more doable for me since I have no rust. Someone with rust will have trouble either way, actually. It was a lot easier than messing with getting the whole ebrake piece taken apart in the hub. That thing is just a pain in the ass.
                  Just my .02 :)
                  - Sean Hayes
                  • MarkH
                    • Jun 2005
                    • 65
                    You have to disconnect the ebrake cables, but be careful that you do not catch them on something when lowering the subframe and damage the tubes they run through. I lowered the subframe a little, removed the differential, and then pulled the subframe with the trailing arms attached. I found it much easier to work on out of the car and was changing the subframe bushings.
                    • Sean
                      • 5793
                      Yea, I had someone in the car guide out my ebrake cables. worked pretty good.
                      - Sean Hayes
                      • Bimmerfanatik
                        • May 2004
                        • 5349
                        Still got to get my subframe and trailing arms to the sandblasters...can't put the stuff in without doing that. This way, I'll never have to worry about them again.
                        • e304me
                          • Feb 2006
                          • 1374
                          i just removed and intalled the whole thing at once. by myself
                          • NC325iC
                            • Mar 2004
                            • 6565
                            im doing the whole assembly as one, got the ebrakes out, not as complex as i thought itd be, getting one of the rotors off took forever thank the lord for my BFH (hammer of thor), all that i have to do now is unbolt the subframe and the diff and lower it out. then hopefully get lucky and have my half ass tool remove the bushings.
                            • etxxz
                              • Feb 2006
                              • 2085
                              can you lower the subframe with the differential and trailing arms attached or the diff's gotta got first for sure?
                              No more e30s for me.
                              88 black BMW OBDII 332is dedicated track [sold]
                              88 BMW OBDII bronzit 332is [RIP 03/08]
                              91 BMW 325i [sold]
                              86 Corolla 'Ae86' HB 20v trd [sold]
                              http://youtube.com/watch?v=pTj7Hn9v5Rs
