I ordered new remanufactured calipers. Lucas Girling front calipers. I painted them and let them sit. The brake line hole was plugged with a rubber plug and the bleeder valve was shut.
One side is compressed already but the other side, I cannot for the life of me get this piston to compress. As far as I can tell, the piston is in straight and doesn't appear inserted improperly - but I seriously can't get the last 6-7mm of the piston back down. Tried a C clamp and a block of wood which broke the wood, tried a C clamp and an old brake pad which did nothing.
Is it possible that it's actually rusted after sitting on a shelf after it was painted for a couple weeks? Like I said, the brake line hole was plugged and the bleeder valve was closed. On top of that, I figure even if it rusted a bit I would be able to get it to budge. I've filled it with PB blaster and I'm letting it soak overnight.
Any suggestions? I have my entire engine out and the MC/booster removed so I can't just hook it up and give it some pressure. I don't have an air compressor either.
