I recently dropped the rear end and put in condor UHMW subframe and RTABs. I had them in for about a day before I hit a curb at about 25mph with my drivers side wheel. I replaced the RTA because it was bent slightly toe'd inward.
Wheel is straight now and drives fine but now I have a creaking coming from my rear every time I take off from a stop or change gear and get on it and the rear is under load. Its coming from both sides it has flexing or binding kind of sound to it.
I was thinking the RTABs cause I didn't put any grease because I thought the UMHW is self lubricating so it shouldn't need any right? my end links are pretty cracked but they have been for a while. Could hitting the curb at that speed have done anything to the subframe or something else to cause the squeaking?
Any help is appreciated, Thanks
