E30 brake temperature monitor
  • dvallis
    • Oct 2015
    • 1474
    I have thermocouple bulk wire sourced. Insulated to withstand 2000F.
    Got a lot cost, easy to mount probe tip figured out for the pad.
    Sourced a low cost stepper motor and MCU with precision analog for the gauge.
    Gage face spec'd out. Will post a pic soon.
    "And then we broke the car. Again." Mark Donohue, "The Unfair Advantage"
    1987 E30 3L Turbo Stroker Das Beast
    2002 E39 M5
    • dvallis
      • Oct 2015
      • 1474
      Here's the gauge face so far
      2002 E39 M5
      • Massive Lee
        • Sep 2006
        • 6785
        You need to add an orange section. Also, remember that heat range depends on pad types. Some totally love 1000°F while others melt at that temp.
        massivebrakes.com
        • dvallis
          • Oct 2015
          • 1474
          Lee
          Since this is for racing pads we can focus on those. From the graphs I posted, racing pads like to operate between 500F and 1200F. It's a generalization but you need to start somewhere. I'm considering 400F at 9 o'clock, 800F at 12 o'clock and 1200F at 3 o'clock.
          To your comment 1200F - 1400F could be orange and 1400F - 1600F would be red.
          Thanks for the input.
          2002 E39 M5
          • dvallis
            • Oct 2015
            • 1474
            The other alternative is a programmable RGB LED ring. That has possibilities and makes the gauge more useful, as in for street pads as well. Looking into this.
            2002 E39 M5
            • dvallis
              • Oct 2015
              • 1474
              So, here's the new and improved gauge face. Has 4 programmable colors for brake state:
              Blue : Cold
              Green: Operating temp
              Yellow: Upper limit of operating temp
              Red: Exceeding operating temp
              Color range is programmed by turning knob on face of the gauge. Press in on knob to change color being programmed. Example:
              Press knob for 2 sec to enter programming mode
              Blue upper limit starts flashing
              Turn knob to set blue upper limit
              Click knob
              Green upper limit starts flashing
              Turn knob to set green upper limit
              Click knob. Yellow upper limit starts flashing
              Turn knob to set yellow upper limit
              Click to exit program mode. LEDs stop flashing
              Gauge remembers color settings when car is powered down. You only have to program it once for any pad type.
              Comments?
              2002 E39 M5
              • SmokeE30
                • 1730
                that looks much easier to comprehend at a glance than the first one or even a digital display
                Shawn @ Bimmerbuddies
                Bimmerbuddies LLC
                717-388-1256
                2971a Roundtop Rd, Middletown PA 17057
                bimmerbuddiesllc@gmail.com
                • Jb325is
                  • 2137
                  What is the response time like?
                  I have a good bit of brake temp data from MX-5 ST cars if you want to check it out, just to see what the temps do.
                  - '88 m54 coupe
                  <3
                  • dvallis
                    • Oct 2015
                    • 1474
                    Response time will be in ~1 millisecond, so you will have the feel of a true analog gauge.
                    Would definitely like to see that data. Please PM it to me.
                    Come to think of it, I'll add a 0-5V brake temp output so the gauge can be monitored and data logged by any racing dash. Like the idea?
                    2002 E39 M5
                    • dvallis
                      • Oct 2015
                      • 1474
                      Color LED ring + driver electronics will add $40 to gauge resale. Ouch. I think that idea goes into "nice to have" bin.
                      2002 E39 M5
                      • Massive Lee
                        • Sep 2006
                        • 6785
                        A sticker costs $1.00 to print ;-)
                        massivebrakes.com
                        • Jb325is
                          • 2137
                          That would be a nice addition for sure.
                          I'll PM you when I get home, I have racing stuff on a separate computer. We use Texense IR sensors, I've never purchased them myself but I get the feeling they're pretty pricey
                          - '88 m54 coupe
                          <3
                          • dvallis
                            • Oct 2015
                            • 1474
                            Texense = $2,400 for 4 sensors.
                            2002 E39 M5
                            • Jb325is
                              • 2137
                              Ha, right + Motec SDL3 = $Dumb$
                              We only run 2 channel (F/R) because we're usually only looking for pad temp ranges @ a certain track, or a difference from one driver to another.
                              - '88 m54 coupe
                              <3
                              • dvallis
                                • Oct 2015
                                • 1474
                                Without the color LEDs.
                                Simple, just works. And the dash / data logger output is a nice touch.
                                2002 E39 M5
