Hey guys the car has e30 m3 rear calipers, e36 m3 front and I rebuilt all 4 calipers. I installed the e30 abs sensor in the e36 spindle up front and of course the e30 ones fit in the rear. Also upgraded the master from Bimmerworld with the 25mm. Issue i'm having is the pedal just sinks to the floor and the brakes just don't work. If I pump them eventually around the 2nd or 3rd time I get some brakes. I've bleed the system the manual way and pressure bleeding about 6-7 times. No air comes out of the system. Having a hard time finding the cause.
Bad master? I was a dumbass and chucked my old one on a cleaning spree so I can't just throw that back in. I also tried with no vac to the booster and its the same situation just with no assist, pedal still just sinks. Does the abs need to be cycled? I tried to drive it around and engage abs but my front left locks up...
