I was replacing the PS lines from the reservoir, and I bumped the brake master cyl and now the master cyl reservoir is loose from the master cyl, and leaking fluid. I went online to find a new part, but only find the master cyl itself (it is a Girling BTW), not the reservoir portion. It would appear that the reservoir just pushes into the top of the master cyl. Do I just need to replace the plugs (item 2)? I assume so since it came apart so easily. Any knowledge on this subject would be appreciated. TIA
Working on power steering, now master cyl problem...
