remove plastic clips from trailing arm ?
  • jwetering
    • Nov 2016
    • 99
    I plan to powder coat my subframe and trailing arms, but I would like to remove, and hopefully re-use, the plastic clips that hold the parking brake cable and brake lines.
    Is there a clean way to remove these, or have you guys been leaving them in place ?
    Thanks
  • mitchlikesbikes
    • Dec 2013
    • 858
    Thanks
    The ones for the hard lines should thread off. I can't remember how the ones for the park brake work
    IG: @mitchlikesbikes
    • jwetering
      • Nov 2016
      • 99
      Two threaded posts. Only way to remove is destroy, only way to install is tap new ones on.
      Thanks
      Sent from my SM-G920W8 using Tapatalk
