ABS acting up
  • cosmo
    • Dec 2017
    • 64
    ABS acting up
    Hi, I got the following problem with my '88 325is:
    ABS kicks in during normal driving at low speeds (mainly noticeable in parking lots) I can feel the brake pedal vibrating. Even stranger, sometimes I can hear the pump coming on when I am not even on the brake.
    I'm running 17" wheels, some suggested that this might throw off the sensors but having the same size wheel on every corner should even out the readings? Plus it does not only happen in tight turns.
    Thank you!
