ABS reinstall?
  • i6mt6
    • Mar 2017
    • 49
    ABS reinstall?
    I have an '89 325i. Looks like PO removed ABS pump. Wheel sensors are present but I have no idea how functional they are.
    Is it worth finding an ABS pump and replumbing it? I assume the rest of the system is present but I have no idea.
    Thanks for the help.
  • i6mt6
    • Mar 2017
    • 49
    Bump
    Looks like I would need (roughly) abs pump, lines to and from pump, and abs computer (in glovebox I believe?). Is that right? Is that easy to get from junkyard cars? Are junkyard parts reliable for these systems?
    Thanks
    • FredK
      • 14762
      The ABS computer is under the driver's side dash. I would check to see that the wiring is still there, otherwise it could be a bear to find a donor car, take all its wiring, and put it back in.
      Your outline of what you need is right. I would find a donor car that has the lines in good, unrusted shape. I would examine how the brake lines were adapted to be non-ABS. It should be easy enough to use a bubble flare union for the rear circuit and a bubble flare tee for the front circuit. However, these cars are not always owned by people with common sense, and there could be compression fitting unions, which I would not recommend using on brake lines.
      • Steve Corbett
        • Jul 2012
        • 449
        I am scrapping a 89 325I that had a complete functioning ABS system. Let me know if you need something.
        Steve Corbett
        1983 528E Scrapped
        1983 528E Sold
        1984 745I
        1984 325E - Sold
        1989 325I Bronzit-Sold
        1989 325I Zinno
        1988 635CSI
        • Metallated
          • Dec 2016
          • 1074
          I also have a complete abs system available, let me know if you need anything.
          • i6mt6
            • Mar 2017
            • 49
            Thanks for the info, I'll do some digging today. The PO ran a soft stainless steel lines across the front for the front brakes out of a T fitting on a short hard line from the MC, the rear brakes are straight off the MC it looks like? I will try to examine the wiring, but I'm not exactly sure what to be looking for.
            Thanks for the input.
            • i6mt6
              • Mar 2017
              • 49
              So the computer is definitely there. I found a bunch of wires that are somewhat cleanly capped off and taped together. I assume the PO just sliced off the big connector? There are a couple of other connectors floating around in the fender area that I'm not sure what they go to.
              Either way, it'll probably be a project for next year. I'll just have to buy some cheap tires so I don't flat spot them.
              • FredK
                • 14762
                That doesn't seem too bad. If you get a complete line set with the ABS pump you can probably re-plumb everything in an hour or two.
                The ABS has a pretty thick wire bundle leading back through the firewall. If it's nicely capped off then it might be easiest to get the ABS pump with maybe 5 - 6 inches of wire attached to it so you can just re-crimp everything wire-to-wire.
                • i6mt6
                  • Mar 2017
                  • 49
                  Well that sounds good. I'll have to look into it once I get the car running.
                  • i6mt6
                    • Mar 2017
                    • 49
                    Well, upon further examination, the soft line running across from the MC to the pass side front does not have enough slack in it to raise it above the engine/trans that it's currently draped across. So I will need to replace it, so I figure I might as well do the ABS plumbing while I'm at it.
                    I'll PM you about your system.
                    Thanks
