Poly subframe subframe bushing slop
  • M///BMW
    • 216
    Picked up some Garigastic poly subframe bushings and there is some slop in the brand new bushing between the inner sleeve and bushing. My old AKG bushings where a tight fit with the bushing and inner sleeve.
    Is this a problem?
  • AndrewBird
    The Mad Scientist
    • 11898
    Depends on how much. Are we talking hotdog down a hallway or a loose slip fit? If you have a pair of calipers, measure the bushing and bore. I would think anything more than .020" difference in diameter would be too much, but that's just a gut estimate. The bushing might swell when the assembly is tightened up.
