Hi,
I have some weird squeaking noise coming from the rear right.
I replaced recently:
Shocks + shock mounts
trailing arm bushings, subframe bushings (initially put in poly bushings but they were squeaking despite greasing them generously, maybe they weren't at fault after all since the squeak sounds very familiar, but this time it's only coming from the passenger side)
spring pads
sway bar end links
Still, the squeak won't go away.
It's mostly noticeable when taking off from standing /low speeds.
Any clues?
Would hate to do subframe bushings a third time this year
Thanks so much!
spring pads
sway bar end links
Any clues?
Thanks so much!
