Help, anyone know what this is and where it's from?
  • Clearprop
    • 54
    Hey guys, need a little bit of help. I removed my front subframe and had it reinforced, however, when I removed the subframe, two metal covers fell off at the same time. I don't know where it's from and where it's suppose to go.
    Any help will be appreciated.
    Thanks in advance!
  • E30SPDFRK
    • 5699
    Between the engine mounts and the subframe. The one with the heat shield is passengers side.
    Byron
    Leichtbau
    • Clearprop
      • 54
      Thanks man! And these just hangs on??
      • E30SPDFRK
        • 5699
        They're a safety piece. Since the mounts are just rubber, these are there to keep the engine from ripping through the mounts and flying around in the event of a crash. The bottom kind of clips over the subframe.
        Byron
        Leichtbau
        • Clearprop
          • 54
          Thank you! I'll try to clip it on the subframe!
