Hi guys, just wanted to check if anyone has had any problems using stainless steel brake fittings on an aluminum master cylinder.
I’m in the process of swapping out my MC for the 25mm e32 unit. I bought some brake line and fittings because my brake lines are in a bad state. I realized that stainless steel fasteners + aluminum is a big no no due to likely corrosion.
I’ve already bought the fittings so I just wanted to see if anyone has used stainless fittings without any problems.
Btw anyone know what material the original lines / fittings are?
