Booster questions
  • 318driver
    • 1714
    Booster questions
    I need to change my booster and have a lack of tools available to me. I am at home home right now and can grab the tools i need, What will i need??
    also any tips on doing it are very very grateful. Thanks in advance
    Drew.
    90 325is
    IE stage 3s and refeshed m20....
  • Mike B.
    • Jan 2006
    • 987
    11mm Flare for brake lines
    10mm box wrench for MC to Booster nuts (ratcheting wrench will work great)
    10 or 13mm socket for Booster to Firewall nuts (can't remember which size)
    12" extension to reach booster/firewall nuts
    3/8" ratchet
    Disconnect booster shaft from brake pedal, remove brake lines from M/C, remove M/C from booster, remove booster/firewall nuts, take out booster.
    • FredK
      • 14762
      They're 13mm.
      Also pick up a gasket for the brake booster, or make your own gasket.
      • Mike325
        • Mar 2006
        • 3685
        Bringing this back up. I am removing my booster right now and I am at the step where the booster is out, but is getting caught on the intake and strut tower. How the hell do you get this thing out with it being sandwiched in there?
        Originally posted by Kershaw
        • xLibelle
          • Aug 2004
          • 2673
          uhhhhh... that doesnt sound right.
          take a picture!! i really cant see this being a problem
          • Mike325
            • Mar 2006
            • 3685
            I got it out. I forgot that my trans was tilted a bit lower because I don't have the cross member in.
            Thanks.
