urethane bushing grease?
  • e304me
    • Feb 2006
    • 1374
    what grease should i use for the trailing arm bushings? I was installing them with some napa stuff called sil glide which contains silicon but with the stuff thats written on the tube it seems like its more for sealing then lubing. WHat do you guys think? i dont want to have to grease them again
  • matt
    • 3732
    White lithium grease. Lots of it
    • der affe
      Technical
      • Dec 2005
      • 8452
      copper or alum ANTI-SEIZE, when the lube eventually goes away it will leave the powdered alum/copper imbedded in the 'thane. then just give it an occasional relube with the white lithium grease spray. the residual metal from the anti-seize will stop the squeeking. go crazy with it during the put together, just wear gloves= big time messy! trust me this is the best way to go with 'thane bushings and the like, been doing it this way for a long time.
      greg
      • Massive Lee
        • Sep 2006
        • 6785
        I second that. Copper grease will last a long time.
        massivebrakes.com
        • Simon S
          • Oct 2004
          • 3758
          mayo
          -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
            Whatever you use it should be a full synthetic. I use synthetic brake caliper grease. It seems to last longer than anything else I've used. But even then I find I need to relube urethan bushings about every six months.
            • StereoInstaller1
              GAS
              • 22679
              Up here in the PNW, it rains a lot. I have been running urethane bushings on all of my cars since about 1992. I got tired of the squeaks and such, so I went looking for a better solution.
              Lithium lasted less than a year before squeaking in my cars.
              I found boat trailer wheel bearing grease (the kind intended for salt water use) works best. I have done well over 200,000 miles between all of the cars on urethane, and have never found a need to regrease.
              This is nasty, stick stuff, will not wipe off of your hands. Wear gloves!
              Luke
              Closing SOON!
              Thanks for 10 years of fun!
              • joshh
                • Aug 2004
                • 6195
                I have your solution...or that is this site has your solution.
                suspension, polyurethane, poly, sway bars, swaybars, anti-swaybars, anti-sway bars, springs, bushings, restoration, prothane, energy suspension, mopar, shelby, polly, poly bushings, polybushings
                The problem with some of the other lubes is they are so viscus that they don't stay put. So you end up needing to relube.
                The lube from the site above is quite thick and you'll still see it in your bushings for a very long time.
                The owner is a local guy...or used to be. He moved out to the coast a few months ago.
                "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
                • e304me
                  • Feb 2006
                  • 1374
                  its too late for any more suggestions. I went with copper
                  • joshh
                    • Aug 2004
                    • 6195
                    If that doesn't work you still know where to get that stuff. Hopefully you wont need it.
                    • Fanzotti
                      • 1255
                      Originally posted by Simon S
                      mayo
                      You learned my secret.
                      • Mike325
                        • Mar 2006
                        • 3685
                        Does anyone use grease on the pins that go in the subframe bushings? I would think you would'nt need to.
                        Originally posted by Kershaw
