Hey guys I need help. I don't know what to do. I replaced my oil pan yesterday and I found out the subframe or wateva u call it(#1 on the graphic) is CRACKED.. very deeply.. its about to brake.. I'm afraid to drive this shit now. how hard is to repplace? price?? total the car??. I don;t know what to do. suggestions. :roll:
Front Subframe /wishbone Help Please!!
Originally posted by ptownTSI View Postpull a good one from a junkyard car. done.IT IS BETTER TO DIE ON YOUR FEET THAN LIVE ON YOUR KNEES - emiliano zapata!
You have to pull the control arms, sway bar, steering rack and motor mounts to pull the front subframe. All pretty easy, should not take more than 2 hours to get out.
Good time to replace the motor mounts too. You can basically remove the subframe without moving the rack. I assume the crack is near the motor mounts? Maybe take it to a small local muffler shop and have it welded if that is feasable.
GL!
Luke
Originally posted by StereoInstaller1 View PostI assume the crack is near the motor mounts? Maybe take it to a small local muffler shop and have it welded if that is feasable.
GL!
LukeIT IS BETTER TO DIE ON YOUR FEET THAN LIVE ON YOUR KNEES - emiliano zapata!
Yea, I would just have it welded. That would be a lot cheaper AND easier than getting a whole nother subframe just cus its cracked.
WillRIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
Welcome e30 (brilliantrot '90 325is) 12/23/06
DaveCN = Old Man
My signature picture was taken by ME! Not by anyone else!
Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.
Originally posted by 325iCabrio View PostI've heard this somewhat common on E30s. Are there any steps you can take to avoid it, or to reinforce the front subframe? I'm going to replace my steering rack soon, and I'm really not looking forward to what I see down there.Originally posted by cabriodster87"Honey? What color is this wire? Is it the same as that one? Are you sure? I don't believe it. OK, it works. Thank you sweetie."Originally posted by Kershawi've got a boner and a desire to speed.
Originally posted by StereoInstaller1 View PostYou have to pull the control arms, sway bar, steering rack and motor mounts to pull the front subframe. All pretty easy, should not take more than 2 hours to get out.Current:
BMW 320i 2d 2.0 m20 -88
BMW 325i Cabriolet 2.5 m50 -88
BMW 316i touring 1.6 m40 -90
BMW 320i 4d 2,2 m54 -01
Originally posted by Rocla View PostFor clarity, control arms and rack don't need to be pulled out of car, just disconnect them from subframe.
I have a spare subframe I am "modding" with new swaybar mounts and beefier motor mount points.
Just so I don't have to make this same post later...
Luke
