Right now I have about 220k on my 1987 325is and I think its about time that I replaced the origional shocks, springs, bushings, shocks mounts and other addition stuff that should be replaced. the thing is i'm not sure what that other stuff is and i would like to put togther an order soon so that i can get going on my new parts.
I hear that oem subframe bushings will be fine, but i should get urethane CABs, but im not even sure what those are. My knowledge of the subframe bushings it about none and i need to know the names of the different bushings that i should replace at this time. i assume that my shock mounts are probabally going to be a little worn and i would like to replace as much rubber as i can in the suspension so that i can hopefull have a little more road feel and control.
The springs im going to use are H & R sports (unless someone has a good reason for me to use something else) and the shocks will be bilstens, but im not sure on the differences between sports and HDs (which one is going to be work best with the H&Rs?)
What I really need to know is what is a good site to order from and what should I do about the subframe bushings, as in what exactly should I order. I plan at getting a bently manual at the same time so that i will not go into the install clueless. The order is going to need to include everything that I will not be able to get locally at a parts store because my car is my daily and id hate to tear things apart and then have to just wait until the parts show up.
what do you guys think, im trying to keep the whole order around $700 if thats reasonable
