I'm going to be ordering all new oem lines (SS would be nice but not a necessity) and front pads/rotors. I just picked up this car and the brake pedal seems to engage lower and a touch softer on the first pedal stomp, then if I pump it once the second pedal pressure is nice and firm and a little bit higher. On that second pedal press the car brakes great, so for the time being I give the pedal a quick pump while braking.
The pedal stays firm and doesn't go to the floor, fluid is fine but I'm sure it's old.
Think this may be from a Master cylinder going bad or just the state of the older brakes and fluid, or normal for the car.
1991 318iS
1991 318iS
