325i rear brakes on 318i
  • hendrixvodu
    • Jan 2007
    • 2514
    will 325i rear brakes fit on a {1985 318i...with drums of course } and has anyone done it....im asking because i can buy a set of rears for $25 with rotors ...and also do i need anything like...different brake lines....ect i know they have a spring system for the parking brake....thats about all i know...hah!
    -His-
    87 e30 325i
    87 e24 m6
    05 e83 x3
    94 e32 740i 5spd
    -Hers-
    89 e30 325i
    18 f48 x1
  • PiercedE30
    • Apr 2005
    • 4220
    swap trailing arms...........
    My 2.9L Build!
    • boom-monkey
      • 1104
      True.
      • hendrixvodu
        • Jan 2007
        • 2514
        much thanks
        -His-
        87 e30 325i
        87 e24 m6
        05 e83 x3
        94 e32 740i 5spd
        -Hers-
        89 e30 325i
        18 f48 x1
        • Mr Deagle
          • 1121
          early 318i trailing arms dont have mounting points for disc brakes
          • Jean
            • 18228
            I did this a few weeks ago, was a direct swap. I swapped complete 325i trailing arms with parking brake cables and got new soft lines (4 of them), rotors and pads. From what I gathered 318i and 325e/i (early non abs master cylinders) are not the same, so I ordered and have a new ATE brake master cylinder that I still need to install.
            Brakes are working fine, although I am not 100% sure right now if it's my left rear/front locking up first under heavy braking. I plan to test a few more times, then swap to 325i/e MC and see what happens then.
            • StereoInstaller1
              GAS
              • 22679
              If you are the sort of chap who likes a firmer feel, you could do a 750i MC instead.
              No better stopping power, just a firmer feel.
              Luke
              Closing SOON!
              Thanks for 10 years of fun!
              • Jean
                • 18228
                iirc all 7xx MC's are abs units.
                • StereoInstaller1
                  GAS
                  • 22679
                  Ah...I chee.
                  I assume you could do a "T" fitting to bypass the ABS ports...but sounds like a bunch of hassle just to get a bit more feel.
                  Oh well. Though I would offer an idea.
                  Luke
                  Closing SOON!
