Difference in front brake calipers?
  • E30 Reaktionär
    Site Manager
    • 14451
    I got an early car with the small strut tubes and non vented brake rotors. It was in a wreck and the PO replaced the pass. side with a newer strut housing and brake set up. Anyway i parted out a 88is and kept the front suspenson setup minus the brake calipers . I'm replacing the contol arms and other stuff on the front so can i use the caliper off of my early setup? Or do i have to buy a new caliper for it when i put the later model brakes on it?
    1992 BMW 325iC
    1978 Chevrolet Monte Carlo
  • Mr Deagle
    • 1121
    check the part nubmers on the carriers, from your left and right side, if they are all the same, it should be no problem
    • E30 Reaktionär
      Site Manager
      • 14451
      There is a differnce in them. But i was looking around in the shed and found the calipers for the front off of the 88is.
      1992 BMW 325iC
      • MikeE30325i
        • 2356
        then i guess your problem has been solved. good luck.
