CAB bolt...
  • e30lyf
    • May 2007
    • 4552
    CAB bolt...
    Hi fellowes. We change the CAB and the bolt was broken. Theirs some tread lefted in the chasis. No idea how to take it off. I need your opinion pls. thanks a lot. :)
    - Fercy -
    Classic BMW Specialists
    Santa Clarita, CA
    www.BimmerHeads.com
  • AlarmedBread
    • Sep 2006
    • 1510
    EZ outs/ lefthanded drill bits. Available cheaply at your local sears etc.
    • BENdashdash
      Tom is not my friend
      • Aug 2004
      • 2506
      same thing happened to me. my $20 easy out snapped. im probably going to just drill it out tomorrow >_<
      • Simon S
        • Oct 2004
        • 3758
        here's how I worked a broken CAB bolt out:
        1) soaked with PB Blaster.
        2) used a dremel with small cut-off wheel to grind a flat slot in end of broken bolt.
        3) heated broken bolt with torch (an effort to 'scare' it out and to temper it)
        4) soaked with more PB Blaster.
        5) then I took an inpact driver with a flat blade in the slot made in in step 2, and pounded that fucker out.
        -----Zen and the Art of e30 Maintenance - / - Zen TOC - / - Zen Summary
        • e30lyf
          • May 2007
          • 4552
          Thanks, Whats PB Blaster?
          - Fercy -
          Santa Clarita, CA
          www.BimmerHeads.com
          • Jand3rson
            • 37587
            Most hardware stores will carry this. Buy the biggest can they have, it's always good to have around.
            • PiercedE30
              • Apr 2005
              • 4220
              i had the same thing happen, but it snapped half-way in the hole. had to drill it out and retap it. worked so far.
              My 2.9L Build!
              • ErykTheRead
                • Apr 2006
                • 87
                EZ Outs are a bad idea unless you want a broken piece of hardened steel in your bolt.
                PB Blaster is incredible stuff. Truly, truly amazing. Doesn't work so well unless it can get in there in the threads, but I have not broken a bolt since I started using it liberally and soaking for a day or two before going to work. Impact wrenches help a lot too to save bolts. Leaning on something with a breaker bar is way more inclined to snap a bolt.
                Left hand drills are the way to go. Just be very careful you don't break one of them, or you have the same problem you have with the easy outs - hardened steel that is a lot less inclined to be drilled out.
                Just keep stepping up the left hand drill size until you either come close to the bolt tap size or the threaded part backs out.
                If you have access to a welder, another option is to weld a rod in there, weld a nut on the rod, and try again.
                -E
                WTB
                Lots of good parts FS!
                • xLibelle
                  • Aug 2004
                  • 2673
                  listen to this man! ^
                  • e30lyf
                    • May 2007
                    • 4552
                    thanks fellowes.
                    - Fercy -
                    Santa Clarita, CA
                    www.BimmerHeads.com
                    • etxxz
                      • Feb 2006
                      • 2085
                      NO!!!:hitler:
                      there's "Easyout" (EZ out) and there's a lot of the same products called differnt names.
                      steps:
                      -NO OIL, NO DREMEL, NO HEAT. PB Blaster Before drilling okay.
                      -drill with a small drill bit right through the center 2-3~4cm so that the smallest or second smallest EASYOUT bit can be used
                      -Tap it in with a hammer...like a man.
                      -Twist bolt out using adjustable wrench or vice grip. should work 1st try...i've gotten exhaust manifold-block bolts out this way. rusted brake bolts u name it this is THE way.
                      No more e30s for me.
                      88 black BMW OBDII 332is dedicated track [sold]
                      88 BMW OBDII bronzit 332is [RIP 03/08]
                      91 BMW 325i [sold]
                      86 Corolla 'Ae86' HB 20v trd [sold]
                      http://youtube.com/watch?v=pTj7Hn9v5Rs
                      • mrsleeve
                        • Mar 2005
                        • 16386
                        Dude you have got it right but I would not use cresent wrenches, The hardened steel will crack off the edges of the square drive end off the ez out. Use either a tap wrench or a 12 point socket that fits the end, or there is lesiley (sp) tools new tap sockets.
                        Originally posted by Fusion
                        William Pitt-
