Fixing the rear geometry once and for all...
  • e304me
    • Feb 2006
    • 1374
    Originally posted by xLibelle
    while in the market for suspension for the GRM, i had that idea of rocker geometry open game as motorcycle components are easy to come by and rebuilt relatively cheaply/easily. i already have some sketches for component design in that regard, in case you want to discuss that topic further.
    But thats all second hand to what has to happen first, the suspension arms and frame.
    What about a trailing arm from stock subframe (Groupe-A style) for lower-front a-arm, a cross bar from equal distance perpendicularly for lower-rear, and the upper arm mounts perpendicularly to the trailing arm from under the car's frame. ..the geometric complexities from the resulting setup makes my head spin :)
    lets work with a different car that already has this suspension, eh?
    that seems like it could work, if you could get the lower rear a arm to be in a position to keep toe constant through the travel range. seems like that would be damn hard though
    • e304me
      • Feb 2006
      • 1374
      whats this grm you guys are talking about
      • matt
        • 3732
        How much of a benefit? A lot.
        Will the car be as fun to drive? Who cares, if it's faster.
        GRM = www.grmotorsports.com
        The only way I can see doing this is to use two a-arms mounted to a new rear subframe around the diff. 2 A-arms and a fixed tie rod to control rear toe.
        • e304me
          • Feb 2006
          • 1374
          you may be able to barrow parts from the ultima gtr, although it seems like it may be a dated design. The car holds like 1.15 gs on the skidpad on street tires but it doesnt have much body roll.
          we should also look at lowering the front control arms outer mounting point to bring back some of the camber gain. I wonder if the inner bushing would fit in place of the outer bushing? that would make it easy as all you would need is a special spacer and a welder.
          • matt
            • 3732
            I already have a solution in the prototype phase for the front end. Results will be posted as they become available. (This will be installed on the WR car.)
            • Mike B.
              • Jan 2006
              • 987
              From Gustave's site...
              If you can create something like this, with CAB's around the same size as the Treehouse racing one's - count me in!
              • Mike B.
                • Jan 2006
                • 987
                You can already do that for $150.
                • matt
                  • 3732
                  Originally posted by Mike B.
                  Those only work with M3 struts, not standard e30 ones. My solution will work either way. (and for e36s also)
                  • e304me
                    • Feb 2006
                    • 1374
                    does it require welding? just make sure that shits strong enough
                    • Mike B.
                      • Jan 2006
                      • 987
                      Matt,
                      Yep, you're right M3-only (works for me though :)). Still really interested in what you come up with though.
                      If you haven't already, check Gustave's site, LOTS of good suspension info there. Should help in avoiding some basic pitfalls before you start fabbing.
                      E304me,
                      The spacers are bolted into place with aerospace grade hardware - should be strong enough.
                      • e304me
                        • Feb 2006
                        • 1374
                        oh i was talking about the one matt was making. I wish that setup worked for regular e30s!!!
                        • matt
                          • 3732
                          I am not going to sell the roll center and bump steer spacers or anything... they will just be for the WR car.
                          The setup I'm playing with for my own car will probably use e30 M3 struts with a spacer like Gustave sells. I am very familiar with his site, BTW.
                          I have a couple of suspension guys who are current and former LMP engineers helping with the project, so I think I'm in good hands.
                          • e304me
                            • Feb 2006
                            • 1374
                            aww come on man why not? are you planing on selling the rear suspension?
                            • matt
                              • 3732
                              Only installed at our shop, if it ever comes to that. It will be outside the budget of most r3v-ers also.
                              The complete 5-lug swap/A-arm rear suspension with all the special tricks would probably run $6k.
                              • Mike B.
                                • Jan 2006
                                • 987
                                You forgot to add at the end of the first sentence - But would be willing to sell to other shops for installation on the shop owners car... :D
                                It sounds like the project is in good hands.
