Control Arms, Bushings, Sway Bars - Oh my.
  • VAPORBLADE
    • Sep 2006
    • 1771
    I am going to be doing the front end here in a few months. Here is what I need so far.
    Tie Rod (Left)
    Tie Rod (Right)
    Control Arm (Left) <----Non M - I cannot justify the cost.
    Control Arm (Right)
    Tree House Racing CAB (Left)
    Tree House Racing CAB (Right)
    Front Sway Bar Kit (with all the busings, bots, parts, and the bar) Brand suggestions?
    Anything I am forgetting?
    '89 "is" = M technic II build mode.
    Shocks, spring pads, and upper shock mounts?
    • StereoInstaller1
      GAS
      • 22679
      Mtree swaybar endlinks
      Closing SOON!
      Thanks for 10 years of fun!
      • einstein57
        • Jun 2007
        • 10780
        i ordered the control arms, solid front bushings, and complete tirerod assemblies on ebay for about $320. Not as good as meyle but they were ok i guess. i went with the st sway bar kit from turner. also not bad for the money. if you plan on ever doing your shocks and spring do them while everything is already out. no point in doing the same work twice. and make sure to get new sway bar links for the front sint the kits don;t come with new ones. ie sells nice spherical ones for $50.
        www.gecoils.com
        • VAPORBLADE
          • Sep 2006
          • 1771
          I am going to be going with a Ground Control set up - should I wait to do this at the same time? I just need to save more $ is all. :)
          • einstein57
            • Jun 2007
            • 10780
            Save the headache and do it all at once. You can knock it out in one day. If you need new brakes do those too. Or at least ss lines.
            www.gecoils.com
