just wondering if the ABS sensor grounds itself on the hub assembly? i had painted my strut/hub assembly when i dissasebled for my C/O setup, and recently the ABS light has been coming on the dash. so i took them off, sanded down the hub area that had paint, sanded the ABS sensor clean, then reinstalled and now the light hasnt come on YET. was it the ground?
ABS sensor ground?
I believe they are. They should get a 12V feed, ground to the housing, and then send a square wave signal to the ABS computer on the other wire.My 2.9L Build!
Originally posted by Ernest HemingwayThere are only three sports: bullfighting, motor racing, and mountaineering; all the rest are merely games.
