Driving normally, after braking i noticed that the brake stuck in the "lightly braking" position. While coasting at around 25MPH the car would slow down and come to a stop within about 800-1000 feet. I could use my left foot under the brake pedal to pry it up while driving (automatic trans) to alleviate the braking, but even doing this, I could not fully return the brake pedal. Brakes function normally, but seemed very sensitive, probably since the brake was already partially engaged. Nothing is caught on or rubbing on the brake pedal itself. When i stopped the car, I felt each wheel and I didn't notice a huge difference it temperature difference between the four wheels. The front wheels seemed slightly hotter than the back.
Preliminary research suggests:
Air in system (Bleed system)
Clog in system (flush system)
Maybe a bad ABS servo?
Any experience in this matter is helpful.
tl;dr: Brake pedal is stuck slightly depressed.
