Rear Wheel Bearing HELP!
  • steinbachphoto
    • Aug 2007
    • 914
    So I think my wheel bearings are wearing out. Becuase when im driving you can hear them almost clunking type of thing. Its not really bad but its still apparent. Is this an easy fix or is it a thing I should leave a shop to do?
    http://www.steinbachphoto.ca
  • onaquest
    • Nov 2005
    • 805
    bearing is about 20 bux, but its tricky to get at it. I searched on this topic before and saw quit a few threads. I ended up buying a tool to pull the bearing, it's an SIR Tools kit, which I bought from Pelican Parts.
    I believe book time is ~ 3hrs. Not an EASY job.
    -Ryan
    http://bbswheels.blogspot.com
    • steinbachphoto
      • Aug 2007
      • 914
      Originally posted by ryno
      bearing is about 20 bux, but its tricky to get at it. I searched on this topic before and saw quit a few threads. I ended u buying a tool to pull the bearing, it's an SIR Tools kit, which I bought from Pelican Parts.
      -Ryan
      would you say i should do it myself or bring it to the bmw stealership? or another local mechanic shop?
      • onaquest
        • Nov 2005
        • 805
        how mechanically inclined are you?
        check out this write up:
        -Ryan
        • steinbachphoto
          • Aug 2007
          • 914
          -Ryan
          I'm not but my step father is who would be helping me and has been since i got my car
          • onaquest
            • Nov 2005
            • 805
            go for it, save some $
            -Ryan
              Bad bearings usually make a pronounced grinding sound. A clunking sort of sound could be worn loose lugs, suspension bushings or upper shock mounts, bad sway bar links, bad half shaft, bad driveshaft u-joints, or even a problem within the differential. Before diving into bearing replacement you need to determine what is causing the noise.
              • 87Blue325iC
                • Apr 2006
                • 1111
                Rear bearings are a major PIA - even with the $300 bearing puller made for the job.
                Aaron
                • steinbachphoto
                  • Aug 2007
                  • 914
                  it is more of a grinding sound. I just couldn't think of how to word it. My step father who is mechanically inclined drove it for a while and he's confident its a wheel bearing issue.
                  But I am replacing the bushings though because there squeaky as well
                  • biglar
                    • Mar 2007
                    • 26
                    Yea i had my rear wheel bearings replaced recently. Buy the $20 part and then take it to a shop. It cost me like $200 to get it done. I heard its the biggest PITA to do it yourself. Saving $200 is not worth that much agony.
                    2005 M3 6MT
                    1991 318i - project car
                    1997 Civic CX Hatchback - DD
                    www.clutchstopper.com
                    • steinbachphoto
                      • Aug 2007
                      • 914
                      what $20 part?
                      • onaquest
                        • Nov 2005
                        • 805
                        what $20 part?
                        the rear wheel bearing. see here:
                        -Ryan
                        • lordofthewaters
                          • Oct 2005
                          • 714
                          That's a good price. That in US dollars or Canadian dollars?
                          Sarcasm is a body's natural defense against stupid.
                          When a man talks dirty to a woman, it's sexual harassment. When a woman talks dirty to a man, it's £3.95 per minute.
                          "My mother never saw the irony in calling me a son-of-a-bitch." Jack Nicholson"
                          Old age and treachery will always overcome youth and skill.
